I'm getting the ladder and flooring insufficient error
ramazan
In the project I did to learn, I get the error that the reinforcement is insufficient and the deflection limit has been exceeded. I am also getting the error out of all floors on one of the two stairs. I changed the column directions and dimensions and got rid of some errors, but I can't get rid of this error. Can you help me?
Yes. I'm using the demo version to learn. If you have time, can you install the demo version and help me? Since the size of the project is large, I compressed idecad. extension is different. When you open idecad and put it in, it opens in demo version.
ladder insufficient error It shows insufficient (in red) when I analyze the project I modeled to work. There are two different stairs in the building and I am getting an error on one of them, can you please help? I don't know what I did wrong. I don't know if the program is a demo, sometimes it gives a geometry error according to his head. When I do it in geometry control, there is no problem. There is a problem in the analysis.
I did all the others except the ladder mistake. When there was no one to help, idecad administrators were helping before, but... there are too many errors in idecad. The interface and the menu are fine, but I don't understand.
"ramazan":17b7hu5i" said:
I made the others except for the ladder mistake. When there was no one to help, idecad administrators were helping but...
Hello, In your project, the arms of the stairs are not connected to the intermediate landing. (Example stairs are attached.) Creating stairs and You can get information about the determination of the support conditions from the following links: -Creation of the ladder
-Determination of the support conditions of the ladder
Some other notes: -It would be appropriate to define curtains in sections such as UTL as group curtains. (Define curtains P002-P008 and P005-P010 as group curtains.) [url =https://idecad.atlassian.net/wiki/spaces/IBB/pages/931793049/Perde+Grobu+Tan+mlama]https://idecad.atlassian.net/wiki/space ... +Tan+mlama[ /url] -For structures with rigid basements, it is recommended to choose the calculation method with two loading states
-There are no beams on the edges of the stairs connecting to the stairs. It would be appropriate to arrange the reinforcement type as flat reinforcement at the top + bottom. -It is recommended to reduce the finite element widths of the floor, curtain and raft properties for calculation accuracy. Good work
"Levent Özpak":3r0cp6bc" said:
"ramazan":3r0cp6bc" said:
I did the others except the ladder error. When there was no one to help, idecad managers were helping, but...
Hello, In your project, the arms of the stairs are not connected to the intermediate landing. (Example ladders are attached.) You can get information about creating ladders and determining support conditions from the links below. -Creating the ladder
-Defining the ladder support conditions
Some other notes; -UTL etc. It would be appropriate to define the curtains in the section as group curtains. (Define P002-P008 and P005-P010 curtains as group curtains.)
-It is recommended to choose two-state calculation method in structures with rigid basement.
-There are no beams on the edges of the stairwells that connect to the stair. It would be appropriate to arrange the reinforcement type as flat reinforcement at the top + bottom. -It is recommended to reduce the finite element widths of the floor, curtain and raft properties for calculation accuracy. Good work
There is a problem with both ladders in the project. In the example I added, there are stairs routes. You can try to recreate these routes by referencing.
