I'm getting the curtain "MUSCLE" issue
Although there is no problem in the project, the curtains are giving a KAS error systemically, I request you to make an examination and help.. version idecad 10.20 INS.MÜH.HÜSEYİN YALÇIN REGARDS file attachment:
Re: curtain KAS problem Hello, In the project you added, the curtain cutting safety problem in its current form is due to the lack of stirrups. The problem will be solved by selecting larger reinforcement diameters from the reinforcement selection dialog. You can check the link below about the curtain cutting safety problem and possible solutions.
Note: If column S09 is modeled as curtain, It would be appropriate to mark the "short head curtain" option from the curtain properties and define it as a group curtain together with the curtains P01-02-03. You can get information from the links below.
Good work
Levent, I did what you said, but I received a warning that you are exceeding the curtain group capacity, and all the curtains gave problems, so my solution became more difficult.
You can increase the reinforcement diameters of the curtain cap areas and increase the number of reinforcements in the curtains with a capacity ratio exceeding.
