I'm getting Relative Floor offset warning
serdagi
Hello, I would like help with the post-analysis report error in the attached project. I wish everyone good work.
Hello, I solved the problem by defining the basement, but what I had to do was to gradually solve the foundation of the ground floor. Is there a solution to this? Also, is the pitch I defined sufficient to run the cascading foundations in conjunction with each other, as far as I can see, the program does not do this automatically. Do we manually edit the foundation drawing after the analysis?
Hello My suggestions; --Separate modeling in the basement is better, --Reduce the live loads in the attic, remove the wall loads, --1. let the floor ladder support be like the other floors, --P01-02-03-04 give the horizontal load from the upper (S002) foundation to the curtains, --Top raft S002 enlarge the floor 50 cm down, P01-02-03-04 will be intertwined with curtain reinforcements. (Still, I do not recommend making a gradual foundation.) Take it easy Unver ÖZCAN
"unver":37cd55mr" said:
Hi My Suggestions; --Based floor separate modeling is better, --Reduce live loads in the attic, remove wall loads, --1st floor stair support like other floors, [color= #FF4040]--P01-02-03-04 give the horizontal load from the upper (S002) foundation to the bulkheads,[/color] --Enlarge the upper raft S002 slab 50 cm down, P01-02-03 -04 curtain will be intertwined with the reinforcements. (I still do not recommend making a gradual foundation.) Take it easy Ünver ÖZCAN
Dear unver, thank you for your suggestions. However, due to the zoning, I cannot show 1 more floor, namely the basement. --Enlarge the upper raft S002 slab 50 cm down, it will be intertwined with the P01-02-03-04 curtain reinforcements. I can't understand what you mean in this sentence. Should I lower the P01-02-03 curtains 50 cm and extend the S002 foundation over them?
What I want to say is not to give the jeans low, but to enlarge them 50 cm so that they are on the curtain. Unver ÖZCAN
