I'm getting max pursantage error
orhan günay
I get the error that the maximum limit is exceeded. It is not solved no matter what I do. There is a problem in only two beams in the nearly symmetrical structure.
I'm getting an error in two beams. It's a previously solved project, I just added small things like fringe, basement window, but it didn't work, whatever I did
Even though the virus program is installed, a virus came from somewhere. IDEV10.09 blocked it. I'm dealing with it. I'll see if I can handle it.
Hello, I made an edit with the demo program attached. --Check your coordinates, --I marked a place in Konya-Ilgın, --Errors in geometry controls were corrected, tiles remained and deleted --DS stuck in K220-K221 on beams, removed HY on beams, --R coefficients were corrected , --Deleting the tile and re-entering for the error D143 cannot create the network, --Group the elevator curtains, --Fixed the column on the elevator side for the B error, --Reduced the right side windows of the basement, Ünver ÖZCAN
