Hello there; There are 2 groups of combinations, calculated and constructive, in the program. The brochures, the website, online trainings, etc., where the program is introduced. You can see that it is clearly stated in places. These combinations are the combinations that are calculated in the Earthquake Code annexes and comply with the values such as rotation angle limited by the Earthquake Code. Other combinations are used for modeling and drawing. A group of constructive combinations will become designable in the upcoming releases. In the programs that make a different combination design, one group; for example Limcon, Ram Connection, Risa Connection; As you will see it is not available. Because steel combinations are so diverse, you cannot expect every program to account for all of them. You have to make calculations for the combinations that are not designed in the program. Or, instead of placing the beam on the column in your project, you can obtain design reports by using 4-bolt or 8-bolt connections. Good work.
