I'm getting a beam nmax error
erdigoksu
I'm getting nmax error in the attached project beam, I couldn't figure out why, I would be very grateful if you could help me.
"erdigoksu":1rg4j559" said:
I am getting the nmax error of the attached project beam, I couldn't figure out why, I would be very grateful if you could help me, have a good day, good work
Hello, If the landing floor named D9 on the ground floor is also in the basement and it is defined and analyzed, the axial axial in the beam load problem will be solved. If there is no slab here, if the beam dimensions are changed, for example 50/30, the axial load problem is solved. Note: K11 is not connected to K35 on the 3rd floor. It would be appropriate to make the beam width 20 cm.
