thank you Unver, I think it will be 2.5-25-2.5. In this way, it will be outside the veil, which will create problems in practice. (probably the contractor will say what the hell is thisK11 Enlarge beam by 5 cm. (2.5 cm-20 cm -2.5 cm) does not give an error. Ünver ÖZCAN
Nd<=0 Under ,1.Ac."tasyapı":12c4oaqf" said:Nd<=0.1.Ac. For fck condition, you need to increase the concrete class or increase the beam cross-sectional area. Berat Bey , the raft foundation I have defined is 100 cm between the 1-1 and 1'-1' axis. When I define the axis and the raft foundation so that this flat is 90 cm, I still get the same beam Nmax error. What is the reason for this?
Hello, Superstructure-foundation Since you are making an interactive solution, the change you make basically changes the element end forces. It is normal. Normal force control of K11 beam: 38.7934- 38.2394= 0.554 tf. It does not recover with a difference of 554 kgf. Nd value at 100 cm is Nd=38.0057 tf. 38.0057- 38.2394= -0.2337. It saves by as little as 233 kgf."construction":3d8ku8ca" said:when I define the axis and raft foundation of this flat to be 90 cm, I still get the same beam Nmax error. What is the reason for this?
Thank you Mr. Hakan, it was enlightening enough.Since you're making a superstructure-base interactive solution, the change you make basically changes the element end forces. It's normal.
