If we comment step by step According to 4.3.4.3, if you model columns and beams in "High Ductile" in your structural system, they are considered "Limited Ductile" and can only be used in DTS 3 and 4. Using this system in your project with DTS 1 and DTS 2 with BYS >=6 If you want, you can solve it with "mixed demand" and therefore you have to provide the condition Mdev>=0.75 Mo. Even if you meet this condition and you model your columns and beams according to the "high ductile system" and you want to accept the system as high ductile, the regulation does not accept this[ /b] and your system considers it a "mixed system" In summary, columns and beams in a hollow block system are considered "limited ductile" under all circumstances and therefore "High Ductile" cannot be resolved."unalmh":2n9s0vzx" said:for two-storey villas, bks =3 bys=8 dts =1 there is no curtain in the system, I just want to solve it with a column. Is it okay if I continue by choosing a high ductility level without choosing karma?
Structures with I=1.5 cannot be solved as "Limited Ductile", no matter which DTS it is. Systems that do not meet the Mo requirement of Mdev>=0.75 are not considered "mixed ductility level" systems. That is, their columns and beams are Limited Ductile curtains are not considered as high ductile. So what is acceptable is the regulation answering "A31". That is, your system means "limited ductile" according to the regulation. Therefore, if you cannot meet the Mdev>=0.75 Mo condition in your I=1.5 structure " High Duct" you have to solve."tavekkul":363zxc0k" said:Hi... I can't do it with limited ductility level since my attached project is BKS=1, I=1.5. Since I chose mixed ductility level and met the bys condition, I continued as mixed and R=4,D according to A31 I think I should be able to do =2.5.
I understand the regulation like you do when I read the regulation. That's why I commented:"tavekkul":3a57r6sd" said:I don't say that I will make a limited ductile solution. I say that I will mix it. So my system is mixed, but it does not meet the 75% condition. In this case, I use the R and D coefficients in A31 because my BYS condition is satisfied. My ductility level remains mixed again. The regulation allows me to continue with mixed ductility level by taking more unsuitable R and D coefficients (R and D in A31), since it does not meet the 75% condition if the BMS condition is met.
