Log in or register now.
with bund Have you done the console beam deflection calculations correctly in the file?If there is no problem when deflection control is performed This data means that there is no problem.Deflection control is performed in ribbed slabs.Information about deflection control can be found in the Ribbed Report.Also, the deflection condition can always be checked for ribbed slabs from the slab properties."bunyam_43":1poc9i6h" said:thanks for your suggestions, I made the necessary deflection conditions. There was no problem, but for example, would it cause a problem in the k33 beam on the ground floor? Does the distance there cause a problem in the span or ribs? Is there any deflection calculation on the ribs
It is not in the Earthquake Code. ."bunyam_43":u7zspn37" said:Is there a limit on the cantilever beams or does this 280 cm long beam pose a danger? Frankly, I have some reservations about this beam and the ribs there
There is no problem in the columns in the project you added."bunyam_43":17zfqtcb" said:https://hotfile.com/dl/162895842/d8f7d59/raifiper402072012.ide7.html I solved those problems but now it gives nd error in the basement. The basement looks delicate despite having curtains
"bunyam_43":3r8g77iz" said:there is no problem with the columns, it just gives an nd error in the x and y directions when getting the report.
"2m project":3kuwa7eg" said:Hi, I downloaded and analyzed your project and I did not encounter any negative or error messages. Even though I received a report using the optional report option, the program did not show any errors. Regards.
"2m project":1z08vlws" said:Hi, I downloaded and analyzed your project and I did not encounter any negative or error messages. Even though I received a report using the optional report option, the program did not show any errors. Regards.
We won't be able to solve your problem like this. Contact us by phone. Phone No= 0(224)220 67 17"bunyam_43":2oczabyn" said:thanks, but after I fixed it, it gave an error, basement floor error, I put it as a new link. I'll add it in my 8th message, now let me add one more thanks
