Reinforced Concrete/Reinforcement Selection dialog Select larger reinforcement diameters in the Retaining wall tab and select the retaining wall do the analysis."tedarmi":tiuq2ibi" said:Removing the old reinforcements after changing the reinforcement diameter and analyzing
"gencideci":2l2574lz" said:Sometimes it gives such errors when we leave a space with the tile edge and define a slab for the remaining part. In these cases, I open a space with the "slab gap" command. I delete the reinforcements in the formwork plan. When I do this, there is no problem with building inspection, etc. Of course, the right thing is to go with the slab edge and create a slab, but in cases where it does not save, you can also try this option...
Your answers have nothing to do with the retaining wall. I think you replied under the wrong topic, you can delete the messages and write them again under the correct topic."gencideci":2l2574lz" said:Another console Activate the static settings of the beam carrying your floors, this beam carries the console floor...
