Select all axis. Enter object properties. Check "Extend to axis boundary". After processing, get die plan again. or When importing die plan, Drawing properties, die from advanced settings Uncheck /base plan section. Import formwork plan. After importing formwork plan, create a formwork plan section with the command drawing/formwork/foundation plan section and insert it into the formwork plan. Good work"ssesli":11z4lc5l" said:Here you go
