Re: stirrup tightening on stud beam ends? Hello, In the current version, end tightening cannot be performed on beams with both ends stuck to other beams. Whatever you write to the tightening zone in the beam reinforcement dialog, the result does not change. If you need it a lot, tighten the middle area as well. Since there is no end-compression requirement for these beams in the regulation, ideCAD designs without tightening. Of course, it would be better if it allows manual intervention.
