How to make an inclined column
neo_serdar
First of all, good job everyone. In a project I am doing, I need to make the column inclined in two directions according to the X and Y coordinates. However, when I enter the column properties and write its slope and elevation, it only inclines in the x or y direction according to the reference point. How can I make the column inclined in two directions at the elevations I want. I would be very grateful if you could help.
Re: How to make an oblique column?
"Levent Özpak":3cjj8pzh" said:
"senem Kıraç":3cjj8pzh" said:
I am a static user of idecad. There are inclined columns in the attic of the project at hand. The columns in the corner must be inclined in both directions, but I cannot define idecad. it is defined only in the x or y direction. How to define an oblique column in both x and y directions at the same time. What would you suggest as a solution.
Hello, If I understood your question correctly, the column can be defined as a polygon column as you mentioned. For this; -Create a closed area of appropriate dimensions with the line command. -Convert polygon to column with the convert polygon to column command. Place it by rotating it at the appropriate angle with the rotate command. The attached example on the subject can be examined. Good work
There is also a sample data in the same place.
Re: How to make an italic colon? Friends, what I actually want to ask is the italic column that I sent in the attachment. The part where the column sits will remain fixed, but the upper elevation of the column inclined to the point where the axes I indicated with the arrow join should be the origin point. I couldn't solve it with a polygon column, I need urgent help, friends. Thanks in advance
Re: How to make an inclined column? Draw an axis passing through the intersection points of both axis you mentioned. place the column at the point, show the point where the upper elevation will be placed before clicking and releasing. (ie the axis direction you just drew) finish the column drawing work. Then edit the column to slant it by the distance between these two intersections. Thus, the upper end will be displaced from the lower end in both the x and y directions. I hope it worked for you.
Re: How to make an inclined column? Unfortunately, Mr. Yılmaz did not succeed or I failed. I want the part of my colon to stay fixed. In other words, the lower left corner of the column, which is the origin point, should be bent at the point indicated by the arrow sign. The part where the column sits will be fixed. ??
Re: How to make an inclined column? AS I DRAWN WITH THE ROUTE IN THE ATTACHED PICTURE, THE COLUMNS WILL BEND IN TWO WAYS?
Re: How to make a slanted column?
"neo_serdar":33l8v4zf" said:
IN THE ATTACHED PICTURE, THE COLUMNS WILL BEND IN TWO DIRECTIONS AS I DRAWN WITH THE ROUTE ?
Did you solve the problem? The column on the lower floor should come as it is. It seems impossible to make it inclined in 2 directions in this program.
"Medeniyetmuhendisi":3b5ijy49" said:
"neo_serdar":3b5ijy49" said:
IN THE ATTACHED PICTURE, THE COLUMNS WILL BEND IN TWO DIRECTIONS AS I DRAWN WITH THE ROUTE?
Did you solve the problem? Likewise, I have a project, the column on the lower floor should come as it is. It is impossible to make it inclined in 2 directions in this program.
Re: How to make an inclined column? It would be nice if there was an update where we can enter values for slope in both x and y directions, such as offset, instead of trying so hard for the slope of the column.
"Medeniyetmuhendisi":2nuu8p0o" said:
It would be nice if there was an update where we can enter values for slope in both x and y directions, such as offset, instead of trying so hard for the slope of the column[/quote ] Hello, Every request, error or suggestion written in the forum is followed and noted by us. Thank you for your attention.
Re: How to make italic column? Thanks for your comprehensive update. I have listed a few suggestions below with an error. 1. The old version number appears in the reports. 2. Import of reinforcement diameters from an existing project. Or choosing which features to import when importing settings from a project. 3. Right-clicking on any static object and getting a report about only that object 4. Entering the gusset beams 5. Creating objects such as inclined raft and elevator curtain on the raft. 6. Automatic creation of reinforced concrete calculation axes in hollow slabs. 7. Automatic updating of the drawings when the rebar diameters of a static project, for which the drawings are made, are changed, for example, and the design is repeated. (Like Revit) 8. Editing the mold plans as if changing the dimension texts without exploding while correcting them. 9. Showing the Shell element results on the mold plan, so that manual calculation axes can be drawn more practically. 10. A detailed macro-like interface for reinforced concrete design rules. For example, placing the beams with more than 5 reinforcements in the bottom row after 3 in the second row and control of the design.
"ofis2a":10oxuayx" said:
Thanks for your comprehensive update. I have listed a few suggestions below with an error. 1. Reports show old version number.
Hello , If this is the report number you mean, the displayed number is correct. No changes have been made to the report program according to 8.61 and 8.60.
2. Importing reinforcement diameters from an existing project. Or choosing which features to import when importing settings from a project.
You can save the settings from a project file with the Export (Save Settings) command, you can load them into another project with the Import (Load Settings) command.
3. Right-clicking on any static object, get a report about that object only
Select the object, You can only get a report for that object, Select a column for example, click the column General report command in the Report menu
8. Dimension texts without exploding when correcting formwork plans
With the fast move command, texts can be moved without breaking objects. Good work
Re: How to make an italic column?
"Levent Özpak":2aisifpg" said:
If this is the report number you mean, the number displayed is correct. The report program has not been changed according to 8.61 in 8.60.
I think the information on the report letterheads is meant. It says "8500HL-..." on me. But this information is our license information as far as I know. It's not the software version.
Re: How to make an inclined column? I need to place the column inclined in two directions, as I have shown in the pictures on the top floor. I added the project in the rar file, I would appreciate it if you could help, good work
Re: How to make an inclined column? Hello; Attached is the curved column project created as you want. I have written on the forum how to do it before, the link is attached.
Best regards...
