How to make a bird's eye on a steel vaulted roof
etriye
Good evening, take it easy. I can't model the places that look like bird eyes on the vaulted roof I'm trying to model in idecad8. If you have any suggestions or ideas, can you help me... I'm attaching the vault roof details as a photo.... thanks in advance for your interest..... idecad data file detail I am asked to model the system completely by defining the coating plate on the photo of the bird's eye.... snow load 120kg coating load 40 kg
Re: How can I make a bird's eye on a steel vaulted roof Hello; In your attached project, I made a very simple assumption and copied the steel columns and beams that you modeled on the slab onto the reinforced concrete beam and completed the data entry between the beams with inter-element coating. For the roof covering in the other direction, I consoled the purlins and brought them closer to the eyelet and tried to model as much as possible without overlap and gaps. I recommend you to do a little more fine work on this model. The situation you need to know is that the steel columns you enter on the reinforced concrete slab are not connected to the slab, they are not suitable according to the regulation. Since it is not connected, the lower end of those two columns looks built-in and the program can analyze. For this reason, the most important thing is the columns I sit on the reinforced concrete beam, this is the correct state. Since there will not be a main carrier system element on the floor in the bird's eye anyway, in this way the loads of the formwork, other columns and beams and the coating can be transmitted. Good work.
Ms. Nurgül, thank you for your attention, I have the old version of idecad 8.103 can you post it that way
Hello there; Your projects are attached. These models are simple models for you to transfer the load. If you want to obtain the exact eyelet geometry, if you are using our architectural program, you can use the tools there and the eyelet can be modeled quickly and you can place the carrier system under the geometry. Good work.
Hello, how did you adjust the inclination of the steel beams, I could not fit the vault in different projects, how many do you enter the jeans, can you help?
Hello there; Select the beam or beams to be tilted, then come to the end of the beam, the cursor will change on the perspective screen, when you click, the move command will appear on the screen, you can enter from this tab for the direction you want. Or you can select the beam and edit it in the properties - general settings - right end elevation box. Good work.
