How to insert beam into elevator curtain
bartayd
I can't get a beam between the column in the figure, how do we model columns like this, are the curtain and column mixed or just curtain
Re: elevator curtain beam problem Hello, Polygon columns are modeled as rod elements. For this reason, beams cannot be inserted between them. It is recommended to enter the elevator curtain as panel objects and model it as a shell. (Small pieces can also be entered as column objects) Good work
