yunussacikk
hello, how are we going to group the curtains? The u curtains I made do not appear as automatic groups.
Hello, select all curtains that will be a group along all floors and enter the curtain properties. Give a name to the group name line. Example screenshot: After analysis, you can see the design of group curtains in the curtain group reinforced concrete dialog."yunussacikk":2sdhb7tn" said:hi how do we group u curtains. The curtains I made do not appear as automatic groups.
In the program, it is checked whether each curtain arm provides 1/6 ratio in geometry control. It is enough to provide the ratio of 1/6. If one of the arms provides the ratio, you may ignore the warning if the other arm(s) does not. Good work"sonsamuray":1w1tz9m8" said:Is 1/6 control performed on group curtains?
