How to get a drawing of basement curtains & stair problem
iek58
hello 1 - I define the subbasement in my project by selecting "Flooring / panel that does not continue on all floors" from the panel element settings in the program. but how can we get the mold plan of them? Can we only have the basement screen scratched or can we have the filling and concrete coating scratched as well? If we can scratch the filling and concrete pavement, how? 2 - As you know, we can easily lower the stairs to the foundation level, but where do we finish the lower level of the stairs in cases where the basement is filled (fill + unreinforced concrete coating)? thanks
Re: How to get the drawing of basement curtains & ask for stairs After your modeling is finished, you can make the necessary adjustments in autocad. You can put a filler phrase in the basic application plan and give the wicker reinforcement information you want under it. If you revise the sections in the basic application according to the filling, it would be good. I saw the masters who applied the 1.5 m column iron short in time, I tried hard until I fixed the job. (As a supervisor) It is difficult to give the floor that will come on the filling without any beams in an ideal way. I think it would not be appropriate since it will be made after the curtains and columns are cast in production anyway. For the stairs, you can put a sprout detail on the autocadden blocking concrete. You must provide the necessary support conditions from the program. If you want, you can add curtains under the beginning of the stairs.
Re: How to get the drawing of basement curtains & ask for stairs Hello,
"iek58":3gr8m87i" said:
1 - In my project, you can change the basement from the panel element settings to "The basement / the panel that does not continue on all floors[ /b]", but how can we get the formwork plan of them?
Since the basement walls, which are given an upper level of more than 50 cm and remain under the beam, are not in the floor slab (the upper level is not in the floor plane), they are not in the formwork plan. It is not drawn. It is drawn in the basic application plan.
as you know, we can easily lower the stairs to the foundation level, but in cases where the basement is filled (fill + unreinforced concrete pavement), where will we finish the lower level of the stairs?
You can finish the ladder at the basement level. If the ladder is being solved together with the structure, you can set the support condition of the lower edge to "fixed support".
can we have only the basement wall scratched or can we also scratch the filling and concrete overlay? it's hard to give without beams. .After your modeling is finished, you can make the necessary adjustments in autocad.
[/quote] Since the tile sitting on the filling will not be calculated, it does not need to be defined as a tile. Editing can be done within the program without the need for autocad. You can make the necessary arrangements in the basic formwork plan by using the 2D drawing possibilities in the later drawing. If the filling is on the raft plate, you can give the weight of the filling to the raft plate.
