aykuttt_35
I am using idecadi for the first time. how can i fix these errors.
In cases where Beam Shear Safety is not provided, beam size can be enlarged, higher strength concrete can be used, improvements can be made in the carrier system so that the shearing force on the beams will be reduced, etc... In case of insufficient ground safety, If the foundation system is a continuous foundation, ampatments can be enlarged, beamless raft foundation system can be applied, If the foundation system is beamless raft, the raft boundaries can be enlarged, ground improvement can be made. etc..."aykuttt_35":1mxlpr7k" said:I am using idecadi for the first time. how can I solve these errors.
Does it work to play with reinforcements? It was solved by increasing the pressure reinforcement in the deflection error, does it work in this problem?"Levent Özpak":3t8b9iwx" said:In cases where Beam Cutting Safety is not Provided; beam size can be enlarged, higher strength concrete can be used, improvements can be made in the carrier system so that the shear force on the beams will decrease, etc... In case of insufficient ground safety, if the foundation system is a continuous foundation, ampatments can be enlarged, a raft foundation system without beams can be applied, raft borders can be enlarged, ground improvement can be made etc..."aykuttt_35":3t8b9iwx" said:I am using idecadi for the first time. How can I solve these errors.
"mkrts88":2qt3koqo" said:is it useful to play with the reinforcement? It was solved by increasing the pressure reinforcement in the deflection error, would it work in this problem?[/quote ] If the Cut Safety issue is due to a lack of stirrups, choosing larger stirrup diameters may solve the problem."Levent Özpak":2qt3koqo" said:In cases where the Beam Shear Safety is not provided, the beam size can be enlarged, higher strength concrete can be used, improvements can be made in the carrier system so that the shearing force on the beams will be reduced, etc... In case of insufficient ground safety, If the foundation system is a continuous foundation, ampatments can be enlarged, beamless raft foundation system can be applied, if the foundation system is beamless raft, the raft boundaries can be enlarged, soil improvement can be made, etc..."aykuttt_35":2qt3koqo" said:I am using idecadi for the first time. How can I solve the errors.
It seems good to me. Support the stairs, solve it together with the structure, in the final calculation, make the width of the finite elements 0.25 m and finish the solution. Unver ÖZCAN"civil engineer":179amv58" said:what did you do, Unver, can you send me a chance, where am I going wrong? How can you comment
Hello, Frequently asked questions for solving column beam joint shear safety problems, you can review item 9."civil engineer":2wvw5sdo" said:I DID NOT DO WHATEVER I DO WITH THE PROJECT, I CONTINUOUS ERRORS EVERYWHERE PLEASE HELP MEYou do not have permission to view link Log in or register now.
