Re: Transfer from Autocad to Idecad.. Hello, you can import the drawing with the ideCAD icon -> Import -> Dwg command. You can create the model by using the floor plan you have imported as insoles.
Re: Transfer from Autocad to Idecad.. I am using idecad 7, I said project - import - dwg, I marked an architectural floor plan drawn in autocad 2007, an empty square appeared on the idecad screen..
