How to enter upper rigid basement floor number in ideCAD 8
gencideci
When I go to TDY Options from the settings in İdecad 8, there is no upper rigid basement floor number. How do we set the upper rigid basement floor number in İdecad 8? it shows up in the reports but I can't set it up, did they put it somewhere else please help?
Re: Upper rigid basement floor number in İdecad 8? In V8, rigid basement is placed in floor general settings. Here, you determine the rigid basement floor by ticking the box according to X, Y direction and floor status. When the basement is entered, the program signals. When entering data, you should remove or add ticks by paying attention to which floors are rigid.
"NYILMAZ":15h0rlhh" said:
The rigid basement in V8 has been placed in floor general settings. Here, by ticking the box according to X and Y direction and floor status, the rigid basement has been placed. You specify the basement. The program signals when the basement is entered. When entering data, you should remove or add the ticks by paying attention to which floors are rigid.
Is a basement floor with a curtain on 3 sides considered rigid?
"vforvendett4":cahbar9u" said:
"NYILMAZ":cahbar9u" said:
In V8, the rigid basement is placed in the floor general settings. Here, you determine the rigid basement floor by ticking the box according to X, Y direction and floor status. When the basement is entered, the program signals. When entering data, you should remove or add ticks by paying attention to which floors are rigid.
Does anyone know the answer to this?
Re: How to enter the upper rigid basement floor number in ideCAD 8 Hello A building with curtains on three sides is not considered rigid in both directions. In general, with the assumption that rigid curtains are sufficient and outside; If there is a curtain in the same direction on both sides, that direction is considered rigid. If there is a curtain on one side, that direction is not considered rigid. Unver ÖZCAN
Re: How to enter the upper rigid basement floor number in ideCAD 8 If there is a structure consisting of a buried single floor (the structure consisting of only the basement) surrounded by curtains on 4 sides, if we mark the foundation and floor as rigid, the program does not perform dynamic analysis and stops the analysis. How to act in this situation?
Re: How to enter upper rigid basement floor number in ideCAD 8
"kemalozkan":3s075fab" said:
If there is a structure consisting of a buried single storey (consisting of basement only) surrounded by curtains on 4 sides, the foundation and solid rigid If we mark it as , the program does not perform dynamic analysis and stops the analysis. How should we act in this case?
