How to do pushover analysis
Mert Kaymaz
Hello, is there an İdecadde push analysis? While making some performance calculations in the regulation, it requires analysis according to shape change. I know that this is done from pushover analysis. Can you help on the subject?
Re: Thrust analysis It would be helpful to share a webinar on thrust analysis or a video with example narration. Best regards.
Re: Push analysis I haven't mastered the normal project yet. We just enjoy the benefits of the program. However, I think that push analysis requires a high level of knowledge and expertise.
Re: impulse analysis Hello; Work on pushover analysis is currently under development. When the deficiencies are completed and added to the program, it will be shared on the forum with the version changes. Best regards...
Re: Thrust analysis Thank you. But the push analysis should be released as soon as possible because most of the regulation now requires an account according to the push analysis. Let it be easy for your work now
