Dear guray kose, I haven't been able to enter the forum for a while because of the intensity. Frankly, I had no hope for his future. You have translated my thoughts. Since I could not define the coating after creating the scissors purlins (the program does not see the scissors purlins as purlins), I could not define the loads. The method you mentioned is just right here. They didn't say that the mind is superior to the mind for nothing Thank you"guraykose":1ih27tmn" said:Actually, the space purlin system you want to build, the space purlin system has not been put into use in ide8 yet, you are actually close to the solution, space purlin otherwise, why not make it manually from the trusses, you have already built the model.The problem is giving the roof loads, there are several ways in this, there are many ways, if not we have the habit of waiting for every solution from the motamot program! Let's come to the solution, there are trusses you entered as a purlin, these are in the primary purlin. we can say, now why don't you place rafters, secondary purlins on these, you will do this only to load the system, and you will disable the secondary purlins in the analysis, it will not enter the analysis with the system, it will only transfer the load. Choose the minimum cross section of the secondary purlins, it doesn't matter if it is insufficient, the purpose just uploading G.Köse
Dear saridurmus Thanks for your reply..."saridurmus":3bpritjq" said:There is no such thing as impossible, as long as we know what we want and push the program's possibility, we will approach the solution.
Dear nurgulkaya; In addition to the model, it is our job to create a purlin and transfer the load to the system. Our aim was to design and solve our lovers in the form of scissors. The only problem was the load transfer as we couldn't define the coating. How can we create the trusses we use as purlin as the 2nd method with the beam command? If I'm not mistaken, we are talking about creating scissors by creating and leveling profiles one by one. Thanks for your valuable answers."nurgulkaya":2vawldxq" said:Hi; Create purlin in addition to your model. After defining the coating on the purlins, remove the purlins from the analysis model as you can see in the attached image In this way, in the analysis result display, you can see that the loads act on the system as a point load at the nodal points where the purlins are connected. You can use this method as a temporary solution. I will make a suggestion about the definition of coating on the trusses. Another method is if you create the trusses you use as purlins with the beam command, you can cover them with the polygon coating command You can enter. You can define a plane in the polygon pavement, then select elements such as beams, columns, etc., on which the cladding will sit. It does not work for trusses at the moment. For a similar system, you can review the canopy from the projects in the project pool in the forum.You do not have permission to view link Log in or register now.Good work.
