Mert Kaymaz
Hello, I have some questions about retrofitting, maybe other than idecad, but if you answer, the question marks in my mind will be gone: 1. How can we determine the ground coefficient in the Retrofit Project? If the project is old, is the ground class determined by opening an inspection pit in the existing building? 2. While drawing a Retrofit Project, shall I enter the status of the existing building and make a performance analysis and then prepare a retrofit project? 3. While drawing the Reinforcement Project, should I first have the analysis done and then arrange the reinforcement of the existing building because as far as I know, we cannot assign reinforcements without first analysis in idecadte. I may be wrong, I would be very grateful if you could help me about these issues, thank you in advance.
