How to build the correct model of this foundation
eraycnar
In the attached autocad file, you can see the anchored cold scissors basic section. What needs to be done to create the right model of this foundation? My thoughts: 1. The socket part is defined as a polygon column and the lower ampart part is defined as a raft foundation 2. To define both the socket part and the ampart part as a raft foundation 3. To define the socket part as a polygon column and ampart part as a singular foundation 1. In the case, the polygon column bar model is modeled A single load can be given for the floor and the floor can be secured with only column punching. In terms of equipment placement; The reinforcement placement did not inspire confidence, as it was defined as a column. In case 2, although 2 raft foundations do not pose a problem in terms of load transfer to each other, reinforcement placement is problematic. In your opinion, what kind of way should be followed while creating a model? Can Idecad provide suitable solutions and drawings for such structures? Thank you.
