How to add windows when modeling the dome
widowswail
take it easy friends. I am trying to make a modeling for the front view and section that I have given in the attachment. It's easy to set the dome with the dome command, but how do we add windows? Or do you need to design a dome from the top of the window and model the level with the windows separately? Frankly, I may not have asked the questions correctly, but the main thing is I want to learn how to model such a structure. I wish you a good day.
Any ideas guys? Is it reasonable and possible to model the dome sitting at +12.30 elevation as a 1 full and 1 empty arc dome and define the gaps in between as a dome sitting at +13.60 elevation? I looked at mosque projects from the team, but unfortunately I could not find an architecture with a similar dome.
Hello there; You can model the section under the dome with the windows as a curtain and open a space. Best regards.
Hello Dear 2m project, How did you model the lower part of the minaret in this model? Can you share the plan or 3d view as a picture? Sent from my SM-N960F using Tapatalk
Hello there; In turn, the Dome sits on the hollow curtains, the Hollow Curtains on the Floor, the Floors on the Beams. Regards.
"2m project":1aucw7vg" said:
Hi; You can model the section under the dome with the windows as a curtain and open a space. Best regards.
First of all, thank you for your interest. The part to be modeled as a void curtain seems to be curved in architecture. I think the architecture is yours. It needs to be fixed as you said. Otherwise I guess we can't find a solution in idecad. Sent from my MI 8 Lite using Tapatalk
"2m project":105ykmmz" said:
Hi, Dome sits on hollow curtains in order, Hollow Curtains on Flooring, Floors on Beams.... Best Regards.
Thank you for your reply. Actually I was wondering how you modeled the minaret plinth. Since there was a problem in the model I created with flooring, I modeled it with the ladder command. I wanted to ask if there could be a different way. Good work.
Hello there; Because of the modeling problem and we think that it will not be healthy, we lower the circular part to the foundation so that it remains inside the rectangular section below in order to avoid problems. We connect the circular part and the rectangular part with intermediate elements so that they work together. We give the part that you model with the ladder in detail in the drawings. Best regards.
