How do I make the section like the steel stair step I added?
leyla12
hello, I created a continuous line for the stair step and said convert and converted it to a plate, but it gave a very thick object. I will be glad if you can help me how can I load a section like the attached or how can I add a thinner stair step.
Re: steel stair step Hello; Create the section that you have added the image of, in a two-dimensional plan, in the dimensions of your image. Then use the convert command. At this time, be sure to pay attention to the units. Good work.
Re: steel stair step yes I did it now it was very important to me thank you. I would have one last question, I will make a steel fire escape ladder and place this plate section between two box profiles. i want to weld this plate section to the box profile.
Re: How do I make the section like the steel stair step I added Hello; The freedoms of the joints are automatically reflected in the mathematical model by the program and are used in the stiffness matrix. You do not need to take any additional action if you are modeling a union. The program-based combination does not give the design report. You can manually check the result of the internal force of the relevant node from the program from the perspective screen right-click analysis display tab. Good work.
