How do I define automatic stirrups on curtains
yunussacikk
hello, when I get curtain prints, my stirrups are very few and how can I make stirrups and crossties with adjustments in the same way for crossties.. I put the mold plan on the curtains. I look at the curtains. There are very few stirrups among the reinforcements.
"yunussacikk":1dtmw1ba" said:
hello when I print curtains, I have very few stirrups and how can I make stirrups and crossties with adjustments in the same way. , is arranged according to the principles specified in the earthquake regulation. If there is no missing reinforcement message on your curtains, we can give a more accurate answer if you exemplify your question with a project such that stirrups and crossties look this much instead of what they should be. If there is missing reinforcement on the curtain, larger reinforcement diameter for stirrups in reinforcement selection Please mark.
Hello, According to TDY Article 3.6.3.3, 4 crossties per square meter are given for the area outside the critical wall height on the walls. In the illustration in the plan you added, the curtains are the basement perimeter curtain and the critical curtain height has not been established as per the regulation. If crossties are attached to each vertical reinforcement, the number of crossties per square meter will increase greatly. The drawing is made according to the number of 4 kiosks per square meter. Maybe it would be appropriate for you to make a note on the sheet.
