"kurcel":zk0ho6ye" said:Hi, I am a new user. My problem is I cannot import dwg. ] You can import using the Import/dwg command from the Project Menu. No need for Autocad. If you add the dwg file that you cannot import, we will review it. Good work
"YasinTezel":1b7uvh82" said:Hi, if you add the dwg file that you cannot import, we will review it.
Hello, I exploded the DWG Drawing blocks and saved it as 2010 version. You can import it to ideCAD. You can work faster if you delete all the drawings that you do not need in the drawing content, such as scanning / furnishing, and then import them."enesucar":3shsh0xq" said:"YasinTezel":3shsh0xq" said:Hi, if you add the dwg file that you cannot import, we will review it.You do not have permission to view link Log in or register now.I can't import this file. Since I couldn't upload the dwg file directly here, I left a link
