How can I move the entire solid 1 meter exaggeratedly?
mcoro35
Good day, I'm still a student, I'm dealing with trial projects and trying to learn. I am trying to design an inclined building for educational purposes. However, on the new floor, the columns start from the first level, not at the intersection. How can I move the entire floor exaggeratedly to the 1 meter shift-column-beam junction point Regards and thanks in advance
Re: floor offset Move to the upper floor, enter the move command, click the select all command, and click the node in the lower right corner (it can be any known place) from the selected objects. Then drop it to the same node of the element in the same lower right corner on the lower floor. will be moved over
