How can I increase column stirrup intervals?
erdigoksu
hello everyone, easy for everyone. In the attached project, the column stirrup intervals are requested fi8 15 and 10 intervals, how can I increase it?
What the column stirrup spacing will be depends on a few things. According to the regulation, it is stated that the column cannot be more than 1/3 of the short side in the upper and lower wrapping regions. This rule applies regardless of account and loads. For example, if your column is 25, the spacing of stirrups can never be more than 8 cm. Increasing the column short side dimensions helps to open the stirrup gaps. However, in order to reduce the shear forces on the column, the presence of shears that can carry more horizontal loads will affect the stirrups. You can add curtains to appropriate places in your model.
The program determines the column stirrup intervals according to the regulations. After the analysis, you can write the stirrup diameter and spacing with the values you want in the column reinforced concrete dialog, but its compliance with the regulations is under your control, and you may also receive a missing As message when you analyze again.
