How can I fix the beam Nmax error
Re: beam nmax error Hello, +35cm elevation has been given to beam K2660. If you want to model the beam as a reverse beam, you need to give the same level to the S8 column. A solution can be made by making S8 Column Top Level +35cm on the 1st Basement Floor and S8 Column Level +35cm on the Ground Floor.
