How are the Retrofit Stages in İdecad
mimsta
Hello there ; What steps should be followed for the idecadde reinforcement project? Could you please add a project example if possible.
Hello, In the attached document, general information is given about the path that can be followed in the program in Reinforcement projects. Good work
I think a front table can be added to the retrofit part of the ide. it is also about entering the cores into the system. about the calculation of core mean and standard deviation values... about obtaining the value of fck and Ej according to the selected level of knowledge... I am doing these in excel right now. it also breaks the report integrity. If there was an information entry screen integrated into the ide, we could directly transfer these core values. I think it will be more collective. ;)
Various performance levels are defined during the retrofit of buildings. Is it possible to combine and report them in the idea? for example, the minimum performance levels required in a building used as a school are HK for 50 years 10%, CG FOR 50 YEARS 2%... my opinion is as follows; if only there was a return repeating the structural analysis before the performance analysis. that is, if we click on the linear analysis button and a front menu comes up, here is the core etc. information entries, the desired performance levels for the building, the purpose of use of the building (by writing clearly), the existence of the projects (reinforced concrete, architecture, approval year date, province, district...) are entered in one go. accordingly, what if the knowledge level of the structure was determined and then the analysis CAN BE CONDUCTED AND REPORTED sequentially for CG, HK?
