Dear colleagues, good day to all. We have a project in which we need to calculate the pile foundation. There will be end piles. I need your information as I have not done a pile foundation project before. I did some research, but I wanted to ask here because there are different opinions. I want to calculate by assuming that the raft foundation will also carry the load, rather than carrying the entire load to the piles. In this sense, in order to provide some economy, I turned to pile raft instead of pile foundation. I have some questions: -How are pile foundation diameters and spacings determined? There are opinions that the intervals should be (2.5-3.5)D or (2-8)D. I have an opinion that the pile foundation may be closely spaced, while the pile-raft may be spaced relatively far apart, is it true? I did some experiments. For example; The load that the pile could carry was 4 times greater than the load on the pile when it was 60cm in diameter and 2m apart. Even if I increase this interval to 4-5m, maybe I will stay within safe limits, but in this case the stakes may not work as a group. How should I make this distinction? Is it right for piles to work as a group? In this case, will the settlement in one pile not affect the others? - Should the upper part of the pile foundation extend to the upper level of the raft foundation or should it terminate under the foundation? -How far should the piles enter the solid layer on which they will sit, is there a certain rate accepted? -In the case of pile foundations, by what percentage would it be reasonable to estimate the raft thickness, should I be looking at the punching factor again? What I am wondering here is whether the raft foundation should be considered as a foundation on its own, or should I think of it as the cap of the piles? -Do we have a chance to do the piles without reinforcement in the program? If we want to make jet grout instead of pile, can we calculate it with the program? The carrying capacity is exceeded by approximately 30%. Thank you in advance to everyone who is interested.
