Honeycomb Beam - To define a honeycomb beam section, right-click on the sections section in the structure tree and click "Add New Section". -We select the section profile type hexagonal honeycomb beam from the opened window and determine the geometric properties of the section. -Click on the steel beam command and select the honeycomb beam section that we defined from the section properties. -After defining the columns and honeycomb beam and determining the loads, we analyze. - In the menu, we come to the "Steel Design" tab and click on the "Honeycomb beam" button. -The design ratios and details of the honeycomb beam can be seen in the opened window. Bending control, shear control in the net area, shear control in the gross area, horizontal shear control, web post buckling control and Vierendeel control and their ratios can be seen in this window. The program makes the honeycomb beam design with these controls. -To get a drawing after analysis and design, we go to the 'drawing' tab from the menu and click the 'steel drawings' button. We select the drawing we want to import from the window that opens.
