Hollow slab cutting safety error
fth_fth
Dear admins, I am getting an error in two of my projects. I am getting a cutting safety error in the hollow floor system that I made for the first time in Project 1. Even though I changed the column sizes, I couldn't fix the error. In Project 2, I cannot change the direction or change the size of the column I get an error because it is not suitable for the architectural project. I'm waiting for your help.
Hello, First of all, in TBDY 2018, serious restrictions were imposed on single-directional threaded (hollow-hole) floors. If there is a hollow block in structures with DTS=1 and DTS=2, the mixed system should be solved and a curtain overturning moment ratio of 75% should be provided in both directions. In Project 1, you do not have a chance to solve a mixed system because there is only one side curtain. Also, you haven't checked 'Apply 4.3.2.4 to all curtain systems' in the Analysis Settings/TBDY Options tab, so there's no need to select 4/5R in the Y direction. Frequently asked questions for the junction area problems you encounter in both projects, you can review the 9th item.
Fixes about Project 1: -The tile type is incorrectly selected in the wizard . It would be appropriate to choose single-direction gear flooring. -There is no curtain in the X direction. It would be appropriate to choose the carrier system type A11. (A11 option will be inactive due to the necessity of solving the Mixed system in single-direction gear floors) -There are warnings about mesh formation problems on the ground floor on the analysis screen. Probably, after modeling the floors, small floor pieces were formed due to the modeling of the basement curtains. To fix this problem: *Run the 'Tile' command while in the plan window. *Click the 'Select all' command in the vertical toolbar on the left of the screen. *All tiles will be selected. *Delete these tiles by pressing the 'Delete' button and define the tiles again. Some determinations about Project 2: - Coordinate values appear as default in the wizard. Arrange the information according to your building coordinate. -Define SP1-2-3 curtains as a group.
- It would be appropriate to choose A15 in both directions of the carrier system type. - Model your eaves floors as one piece, not as a console on the console. Model the floors D13-14-15 on the 4th floor as one piece with D7. Good work
