*You can define a gap on the slab with the tile gap command. * With Reinforced concrete calculation axis edit command, you can select the reinforcement types of the reinforcement axes, and with the Rebar Calculation axis change geometry command, you can determine the locations and working distances of the reinforcements. *You can examine the slab analysis results in the perspective window. Good work
