hollow floor stairwell help needed
prol0gic
I would be very grateful if you could do the general checks in the attached project and help with the necessary corrections. Is it inconvenient to make the stair space in the project as in the left section, your ideas are very important, thank you in advance, good work.
Hello 1. Since the reinforcement axis of the D04 slab on the 3rd floor is faulty, the slab operation cannot be determined in the analysis. Delete the tile and redefine it. *Since the D103 slab on the ground floor is supported on the beam from 3 sides, the reinforcement types Reinforced Concrete Calculation Axis Edit command can be edited as top+bottom flat reinforcement. Good work
