Hollow floor beams
actombo
Hello, I will solve a hollow block project for the first time. There is a subject I am curious about. 1) Do we need to add the load of the material we will use for the hollow block filling to the constant load? 2) Also, does it automatically calculate the load of the beams, not the main beams? I examined the report section and could not see it. Or do we have to manually calculate and enter it? Good work
Hello, 1- In ideCAD Static, you need to add the weight of the hollow brick to the coating loads that come ready. 2-The loads of rib beams are calculated automatically according to the cross-section and are indicated as self-loading in the rib floor reports. You can examine the example in the attached project.
"YasinTezel":2fgh5b51" said:
Hi, 1- You need to add the weight of hollow bricks to the ready-made coating loads in ideCAD Static. 2- The loads of rib beams are calculated automatically according to the cross-section and are indicated as self-load in the rib flooring reports. You can examine the example in the attached project. .
Yasin, I can't find the dwg I imported, is there any easy way to do it in idecad?
8 Import by activating the move to origin option in the version. If you are using old versions. Before importing, move your file to the origin in Autocad, delete unnecessary drawings if there are any. When you zoom borders or Zoom all, check the drawing borders so that only the drawing you want to import appears. Then import it.
