Thank you for your interest and concern. You have reached the solution by inserting the S14 column into the side parcel, unfortunately, such a solution is not possible. I don't know if this contributed to the system or if it was accidental. ? Even though I tried very hard, I was able to save the elevator curtains by doubling in the same direction. In this system, I think why there is a relative floor offset in the Y direction, because the building is a little long and hollow, what do you think? The issue of stairs is always on my mind anyway. I have been supporting and constructing ladder solutions simply as you can see in the attached project for years. But it seems as if it has no effect on the system. For this reason, I also add more to the wall load of the beams on the stairs. What do you think about these solutions? how do you solve the stairs in the system? Finally, the D7 slab is approximately 40 m2 (I could have divided it into two, but I think the two ends of the stud beams would cause more damage to the building), since the span exceeds 4 m, transverse teeth are required. Normally, after I finished the calculations and drawings of the transverse thread, I was drawing the transverse thread with my hand on the mold plan. I asked the ide authorities at the time, they gave advice in this direction. I've never done it. But I can make cassettes instead of ribs and fix the transverse gear in the system, do you think it makes a difference which is the more correct solution?
