Help
semih5252
AT THE PROJECT I WORKED AS A RIBBED FLOOR, IT GIVES A TYPICAL BEAM ERROR I DIDN'T FIX IT WHATEVER I DID. I'd appreciate your help.
"semih5252":1ni8jyc7" said:
I WORKED AS A RIBBED FLOOR AT THE PROJECT I GAVE TYPICAL BEAM ERRORS I CANNOT FIX IT WHATEVER I DID I GET YOUR HELP.
Hello. (place shown with ) Also, D02-05-10-13-16 etc. rib slabs' mid-range tooth spacing is not compatible with other teeth. ]http://idecad.com.tr/destek/egitim6/static/nervurlu_doseme/nervurlu_doseme.html[/url]
Good work
Mr. Levent, first of all, thank you for your attention, I have corrected the error number 2 in the image, but I could not make the tile ribbed in the area you indicated with number 1, it always gives an error in the geometry control..
"semih5252":377eyfx5" said:
levent, first of all, thank you for your attention, I fixed the error number 2 in the image, but I could not make the tile ribbed in the area you indicated with number 1, it always gives an error in the geometry control.
The corrected version is attached.
