teknikisler
I am working on a 7-storey building project, 2 basement floors, in the 1st degree earthquake zone. In the project, it is not desired to enter the ground except for the height of the foundation. So basements are not underground. There is no rigid basement. I solved the project as attached, but it gives negative ground tension error. I need your opinions on the project. I changed the mold plan 4 times, now my head stopped. I can't see right or wrong. We cannot change the column directions much on the project. We can change the column sizes not on the short side, but on the long side. Curtains can be placed around 13 axles, 14 axles, K-5 axles, around stairs and around elevators. I deleted the upper layers because the file size is large. I need your opinions. Thanks to those who are already interested.
