help with radial please...
klinker
I wanted to solve the foundation of the project I have given in the appendix with a raft foundation...but no matter what I do, it doesn't save it...(I even tried the foundation thickness of 300 cm) ....I will be very happy if you help this new graduate brother.. thanks in advance. goodbye..
It would be better if you correct the items I mentioned about the project. 1) You should get the rigid basement number -3. 2) You need to make a superstructure interactive solution. 3) If you have entered the ladder into the system, it would be appropriate to define the support conditions and solve them as semi-rigid. 4) It may be helpful to check the beam lengths. 5) The raft saves as I throw it, but you can make it a little smaller
Thank you very much for your interest, Mr. Omer. I examined the project you sent. Isn't the reinforcement diameter a bit too much? ...there is Q24...it still gives an error when minimized...thanks again
"klinker":2wo7ue27" said:
thank you very much for your interest, Mr. Omer...I have examined the project you sent...don't the reinforcement diameters a bit too much? ...there is Q24...it gives an error when it is reduced...thanks again
In the project I sent in the attachment, it saves 18 degrees, but the building stresses are too much, I recommend you 20 here. NOTE: I don't know if you are aware, all beams carry console floor. I wish you the best
