Help with project mod count and screens
mgondem
In my attached project, the number of modes gives an error (ritz is selected) It also gives a pitch error for a24. What are your suggestions? I would be glad if you help.
Hello, although there is no curtain in the Y direction (A24), you have chosen as a curtain. Put a curtain in the Y direction. Unver ÖZCAN
In the last item of the TBDY Wizard, other options are disabled. I can only select the link beam gap curtain and curtain option. Is it not possible to solve it this way? Also, it gives different errors when I set the curtain in the y direction. I haven't tried it either. Sent from my VKY-L09 using Tapatalk
Hello
"mgondem":dhc7skf5" said:
I can only choose the option of hollow curtain and curtain with tie beams.
You should choose the A24 option in both directions. The A23 option you mentioned is not suitable for your project.
Is it not possible to solve it this way? Also, it gives different errors when I pitch the y-direction.
Not possible. When you put the curtain in the Y direction, you can achieve 0.75 ratio. If you can't, turn to cassette or column beam system. Unver ÖZCAN
