Help with dome design
teknikisler
We want to make a show hall with octagonal exterior openings of approximately 15*15 meters. There will be a dome above it. But the dome will be 180 cm above the normal floor. Wooden roof cladding will be made on it. The dome will not actually be visible from the outside, but is intended only for an acoustic effect. In the design of the dome, I entered this 180 cm part as a panel in the project, but such a design does not exist. How should I design this section? I have to think like masonry and tie my beam with vertical beams. Or should I think of it as a panel and attach it to the beams that way? How can we define such an elevation below the dome? Or should we not make a dome at all? I will be grateful if you could help me
You can see the attached link. You can do it by using a vault object instead of a curtain. Check out the attached picture.
Thank you very much for your interest and quick response. But how did you do that, I couldn't. I will be grateful if you could help me.
