help please
mcoban
First of all, take it easy everyone, my problem is about the stairs. I want to solve a staircase without a landing in a building with different floor heights (floor 4.30, 1st floor 3), since the starting step of both stairs will be at different distances, there is a floor space in between (3 dimensions). This gap is not visible in the ground floor formwork plan. Should we draw this gap manually?
Dear mcban; I think copying the D08 slab on the upper floor to the ground floor will be the solution for you. But after copying you need to create a tile gap. Also, it is useful to change the live loads on that floor. I hope I could help.
Mr. mcoban My suggestion: -- Solve it as a semi-rigid diaphragm -- The ladder you modeled is insufficient to support the columns (S16-S18) on the mezzanine floor. --I fixed the landing. (I fixed the staircase modelling. I made the K06 beam an inclined beam.) --EK: Arrange it as I gave in the staircase image. (I didn't correct the 1st floor.) --Place a small curtain on the foundation part of the staircase (while drawing the details). Take it easy Unver ÖZCAN Mr. celikus
