Hello, I have some questions about how the heat difference calculation works in the program. For example, I want to calculate the case where the structure is exposed to a temperature difference of 10 degrees. Should T1: 0 and T2 : 10 be entered in this case? Or are both values independent of each other? or if T1:-10 and T2: 10 are entered, will the structure be calculated based on a total temperature difference of 20 degrees. there are also cases where the heat difference calculation is not used in capacity controls and concrete design, or I could not find it. what is the reason for this? thanks.
