memorandum
Greetings, Professor Ruhi Aydın's Steel Structures book in compliance with AISC 360-10 Regulations has a connection example with Bolt and Head plate on page 251. While I was examining this example, I noticed some differences while checking the solution in the program. 1- For the yield strength of the steel column or section 275 mpa rupture 430 mpa (S275), the program only takes the fu value of 0.41 kn/mm2. There is an option to change it, but why does it automatically see 0.41? 2- In general, although the formulas are the same, there are differences in the calculation of the sheet net cross-sectional area (for example, Afn). He said to use the Mn formula, but the program used the Mn formula directly in the calculation. 4-For reference [1] Muir, LS and Hewitt CM (2009). Design of Unstiffened Extended Single-Plate Shear Connections. Considering that you gave Engineering Journal, 2nd Quarter, 67-79, I think that's why there are differences. I could not obtain this publication in pdf or by purchasing. Where can I get the Engineering Journal book? 5-There is a shear and moment load in the combination that the program automatically finds the most unfavorable loading. How can we give the moment and shear force we want to this independent combination? Good work.
