Hasp key not found h0007 ( hata )
omerckr
friends ideCAD stattik 6.0. I uploaded hasp key not found h0007 from idecad.com I am giving this error, if anyone knows the solution, can they help me? Thanks in advance.
friends, I forgot to write my operating system is vista .... I downloaded the program from idecad itself, ideCAD Static 6 (Ver 6.0055) I did not understand what key it wanted .....
"omerckr":c9xo3x7d" said:
friends I downloaded ideCAD stattik 6.0. Hasp key not found h0007 from idecad.com I am giving this error. If anyone knows the solution, can you help me? Urgently thanks in advance
Hello, if you are not licensed user, the reason is the lock problem. or If you still have not upgraded from version 5 to version 6, you cannot run version 6 with the lock you have. If you are a user with ideCAD Static 6 license, there may have been a software problem with the lock, you need to download the file below and install it. /hl/windows/installed/redistribute/drivers/HASP_HL_driver_setup.zip]ftp://ftp.aladdin.com/pub/hasp/hl/windo ... _setup.zip[/url] Good work.
Mr.ömerckr, if you are not a licensed ideCAD user, you can download and use our demo version. In the demo, you can use all the possibilities of the program (except for printout) and record in demo format without floor, object, time restrictions.
"omerckr":xvgcpuks" said:
friends I downloaded ideCAD stattik 6.0. Hasp key not found h0007 from idecad.com I am giving this error, if anyone knows the solution, can you help me, thanks in advance
If you are a licensed user, you may encounter this error for three reasons. : 1- You may be running the program with the wrong lock. 5 lock does not open version 6 or something similar. 6 version requires version 6 lock. 2-The lock may be broken. You can send the lock to ideYAPI Bursa office for checking.[/i] 3- The special software of the lock may not be installed on the operating system. This process is done automatically during the installation phase, but this process may not have taken place due to some unexpected factors. the program must be installed.
If you are not a licensed user; Chinese lock is required. Our demo version works unlocked. You can use our demo versions for your reviews. Good work...
Hello, you have installed the licensed version instead of the demo. You are encountering this error message because you do not have a lock. Demo links: This version is deprecated. Click
for newer versions.
