Group (Polygon) curtain that goes down to the subfloor
yaliniz
Hello there ; I have two questions 1) If the curtain that is flooded in the basement, as in the first two pictures, is included in the curtain group, a part of which continues above, should we define any group of curtains in the basement, that is, on the lower floor? 2) I know that in the regulation it is necessary to define a group of curtains for curtains such as t, l, c. But in a situation like the 3rd picture, should we consider it as a curtain group?
Re: GROUP CURTAIN Hello, 1- Copy the curtain group you defined on the ground floor exactly to the basement floor. (Floor copying can be done only with selected objects) Separately define the ground curtain connected to the system curtain in the basement floor. Define the curtains that continue to the upper floor as a group in the basement as well. or you can divide the existing basement floor curtain from the upper floor curtain node with the command. 2- If the curtain group continues on all floors, even if it is in types other than the general UL type, define it as a group.
