In the regulation, CUT style curtains are requested to be modeled as polygons. Although these requests are met with the group curtain option in the program, some municipalities we work with (especially MALTEPE MUNICIPALITY) definitely want the curtain to be modeled as a whole and the results (bending, shearing, overturning, axial forces) to be given as a single polygon curtain. No matter how much he explained, he firmly stated that he would not look at future projects this way. Including all projects drawn with idecad. Our request from you is this. After the curtain is modeled, if an option such as create polygon curtain is added and all the results are given under a single name, this problem will be solved. It would be better if the shear forces were given as polygon curtain x direction and polygon curtain y direction, at least the demands of the municipality would be met.
